06-29-2016 04:11 AM - edited 06-29-2016 04:15 AM
I've developed a RT system on a cRIO 9030 that is using a web interface as GUI. From this GUI the operator is controlling motors and other types of equipment that is critical to stop when the user demands. If the connection is lost the motors has to stop automatically.
I've testet different methods to detect a client loss, but none has worked. Too me it seems that the "RP.Client Connections" (see picture under) does not update if i pull the ethernet plug.
Is there any other way to detect a client loss?
EDIT: It detects the loss, but the time it takes is way to long.
06-29-2016 05:35 AM
06-29-2016 06:17 AM
The cRIO needs to know if the client in controll is still there.
I finally made the ping command working from the cRIO, and this is sufficient for this task.
(I had to add the "-c 1" to only ping once for the terminal window to reply from my command).
If no ping packets are received i consider the clint connection lost.
If there is a simpler method to check for a connection to the operator please let me know! 🙂
06-29-2016 06:32 AM
