cRIO and PC synchronization with 1588 on Ethernet card
Hi all,
I would like to synchronize my cRIO with my computer under Windows 7.
 - Is that possible to implement 1588 protocol in both hardware using the PC as master clock and cRIO as slave ?
 - Where can find exemples ?
The goal is to acquire temperatures via NI-9212 modules and communicate from cRIO to PC by implementing a lite version of IENA protocole.
In the final achitecture I could have multiple cRIO.
Requirement :
Don't use NI 6682H card or other card
Can use NI Sync module
Use on borad ethernet card
PC under Windows 7 with LV 2013
cRIO-9067 under LV-RT 2015
(2,923 Views)
Accepted by topic author Marc-Henri
here's some documentation about NTP protocol implementation on cRIO running Linux RT and host computer with Windows
- Installing and configuring NTP on Linus RT
- How do i configure a NTP Time server on Windows
Adrien
Adrien M.
Certified LabVIEW Developer
National Instruments France
Travaux Pratiques d'initiation à LabVIEW et à la mesure
Du 2 au 23 octobre, partout en France
(2,855 Views)
This will be good. We already use Meinberg as NTP on our achitecture.
Regards
(2,851 Views)
