03-02-2007 04:12 PM
I am trying to do a DMA transfer from the cRIO RT controller to the cRIO FPGA. Both the FPGA code compiles and runs, and the RT code compiles and runs. However, when I get an RT error
(error -63001) NI-RIO FPGA Communications
Framework: (Hex 0xFFFF09E7) DMA from host to FPGA is not supported for this platform.
I have version 2.2.0 of the NI-RIO driver which was told by NI should support this direction of transfers.
03-02-2007 05:32 PM
Hi gregl,
Which version of CompactRIO controller are you currently using? The cRIO-9012 Controller supports DMA transfers from Host to FPGA and FPGA to host while the cRIO-900x series controllers only support FPGA to host DMA transfers.
Steve
03-05-2007 09:40 AM
01-15-2009 04:15 PM
01-16-2009 09:07 AM
03-13-2012 02:46 AM
Hello , i am buying a cRIO 9073 , i will have same error??
Thank you.
03-13-2012 05:59 PM
The cRIO 9073 supports Host-to-FPGA DMA transfers. cRIO-9004 and cRIO-9002 are the controllers that don't support Host-to-FPGA FIFO communication.
