cRIO-9144 (EtherCAT slave) freezes after master's clock changes
I have these chasses:
  • cRIO 9024 (EtherCAT Master)
    • 1x NI 9023
  • cRIO 9144 (EtherCAT Slave)
    • 1x NI 9023
The EtherCAT Master has these software items installed:
I monitor all the system's I/O channels in the Distributed System Manager. I apply an input, and I can see the values update.
However, when I manually change the current time on the cRIO 9024, the EtherCAT slave stops working:
  • In the DSM, all of its channel values are completely frozen, while the EtherCAT master's channels still oscillate around the noise floor.
  • The "ERR" LED on the cRIO 9144 does not turn on.
(I also tried making the cRIO 9024 a PTP slave, and updated the PTP master clock. The same thing happened -- EtherCAT slave stopped transmitting data)
Is this expected? My full project will involve many CompactRIOs, and I need to keep all their clocks in sync (using something like PTP or NTP). How can I synchronize the different cRIOs without losing EtherCAT slaves?
Thanks in advance
Certified LabVIEW Developer
(2,532 Views)
Hi JKSH,
I recommend that you post to the Industrial Communications forum. That forum focuses on products such as EtherCAT systems so you may receive better responses there.
David C
(2,494 Views)
