06-26-2015 02:58 PM
I have a cRIO 9064 using the C-Module 9402 as a fast DIO in a SCTL. I use it in a digital delay pulse generator (DDPG).
I have succesfully implmented the DDPG, triggered with an internal generated square wave clocked at 1 MHz.
and I measure perfect output pulses on an oscillascope.
My implementation is basically a clone of: http://www.ni.com/example/31131/en/
However when I try to trigger from an external 1 MHz, 6 volts amplitude; duty_cycle 50%, square wave coming in on the DIO3
there is no triggering, as seen on the Ticks_Between_Trig - which should be about 40, when there is correct triggering.
I have use the method 'Check Status' to make sure the 9402 is ready before running in the SCTL.
( Note: while it is labled Mod3 in teh screen shot, it is actaully Mod1 and it simple a namign mismatch - which when fixed does not change anything. )
I do not see any digital HIGH when monitoring the trigger input, which I do when using the internal trigger.
The LED flashes, often enough even though in reality at 1MHz.
My question is what trick do I need to have the 9402 DIO read the input signal.
I have followed the instructions here:
http://zone.ni.com/reference/en-XX/help/370984R-01/criodevicehelp/crio-9402/
but perhaps i missed something.
thanks
Michael
Solved! Go to Solution.
06-26-2015 05:42 PM
Solved,
I had a bad input pulse generator that was flacky.
When I check the pulse amplitudes on an oscilascope but then day later when I fixed my code to include the C-Module ready method,
the pulse amplitude was nolonger working, but I was still trying to test with it,
Finally I rechecked on the oscillascope again the trigger signal to find it not suffecient.
Old eqiupment getting warm.... then not working.
Michael
