cRIO-9024 + NI 9113 Chassis + NI 9881 (CANopen) FPGA Compile Problem
Hi batuypn,
Good to hear everything is fixed now.  I actually found another solution that worked as well (as I had the same issue happen).  It seems that the ccmux file was corrupted.  If we take one that isn't corrupt and replace it then it should compile fine after a rebuild.
Matt S.
Industrial Communications Product Support Engineer
Message 11 of 11
(532 Views)
