Hello:
I'm new at this. We have purchased a cDaq9188 with a bunch of modles (9205, 9184, etc), We are running DaqMx
I have created a .vi that just reads the channels, converts them to an EU via a linear graph (y=mx+b), and then displays the data. The data can also be stored in an excel spreadsheet. I have included the .vi
I can't get any better than 1 sample per second. If I am just running one or two modules, I can add the sample clock timing in the programming, but cannot get it running any faster than 1 S/s. Could this be the network? On the network, we are just running a cheap network switch at 10BaseT. I noticed this because we purchased the cDaq usb version and I have to put in the timing as it runs a lot faster.
Any help or suggestions would be appreciated.
The MR2-SF file is the main file. The Linear (subvi) file is just the linear equation to convert from raw voltage to EU.
Chris
