10-31-2011 11:21 AM
Is CAN bus monitor function available in NI- XNET 1.1.3 palette? If not is there any way around to bring the bus data stream to the front panel?
Thanks.
11-01-2011 04:03 PM
There are two ways to access the bus monitor, you can access it through Measurement & Automation Explorer as discussed in this KnowledgeBase: http://digital.ni.com/public.nsf/allkb/29B1BA306ADB423A8625761800594631?OpenDocument
Or you can use an example from the LabVIEW Example Finder titled "CAN Input Stream to TDMS Logfile.vi". You can remove the option to write to a TDMS file and just monitor the input frames on the front panel. To locate this example
I am attaching a screen shot of the block diagram to give you a better understanding of what the example I am referencing does.
I hope this helps.
Regards
03-18-2016 01:24 PM
How do I go about removing the option to remove the programs ability to write to the log file? I have been trying to delete a few things within the program to disable to feature because I only want to display the messages being exchanged on the front panel.
03-18-2016 03:00 PM
Just remove the functions that create the TDMS file, write to it, and close it.
