05-11-2006 09:45 AM
05-11-2006 10:40 AM
05-11-2006 11:52 AM
05-12-2006 11:06 AM
05-15-2006 09:17 AM
Jarod,
I am attaching the VI along with INI file as well as the DLL files that are needed to run this VI. I currently am running this vi from the C:\Temp folder where both the INI files and the DLL are located. The first thing this vi does is converts the INI file location to a string using the path to string function and then and then loads the string into the dll call function. When the VI runs in development mode you should see "OpenInstancesAndFPAs: Success" in the Error out box which means it worked. However when I create the exe file and run it I get the following in the Error Box "OpenInstancesAndFPAs: No instances were opened succesfully" it almost seems to mean that it is appending something to the file location and therefore is pointing to the wrong file location, But I cannot seem to figure out where or why???
Phil
05-15-2006 10:10 AM
Nevermind, I got it figured out 🙂 seems as tho there were more than just 1 dll files that I needed to add as support files. Thanks for the help.
Phil
10-16-2014 11:49 AM
I was exposed to such problem:
* in developement mode is OK
* error (impossible to open a new instance) in build app
Additional DLL must be included in build - "MSP430FPA1.dll"
API DLL - 1.22 Mb
Thanks for posts !!!
P.S.
I used the latest ones (attached):
MSP430FPA_ver_5050.dll
MSP430FPA1.dll
