building a 2D array from same location of a 1D array
I am very new to LABView platform. I am trying to build a 2D array from a 1D array. The 1D array is updating data in the same cells. I have attached a mock-up image of the objective.
It will be great if anybody can kindly advise me.
Thanks you!
(2,629 Views)
On the upper right side of the Forum window is a list of several site with pretty good LabVIEW tutorials.  Your question is undoubtedly handled in all of the initial tutorials -- spend a little time, learn a little LabVIEW, and solve this problem yourself.
(2,616 Views)
You can literally do what you're trying to do using a Build Array node. This is very basic, so you should really invest a little bit of time in free training like Bob said.
Would you plan on writing code in Matlab/C/Java by just sitting down and throwing words together until it works?
"Give me six hours to chop down a tree and I will spend the first four sharpening the axe."  - Abraham Lincoln
Here are some free training tools primarily focused on LabVIEW and NI hardware to help get started.
NI Learning Center
NI Getting Started
-Hardware Basics
-MyRIO Project Essentials Guide (lots of good simple circuits with links to youtube demonstrations)
-LabVEW Basics
-DAQ Application Tutorials
-cRIO Developer's Guide
Learn NI Training Resource Videos
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
(I personally suggest the 3-hour or 6-hour intro videos)
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(2,590 Views)
