I have a question regarding the allocation of the output buffer. I have
a digital I/O card PCI-6534 and I use the driver NI-DAQmx 7.4.0f0. I
would like to generate a digital output using different clock rates.
For example, I need to write 500 samples at 1000 samples per second and
other 500 samples at a rate of 10000 samples per second. the simplest
solution is to prepare two different waveforms, write the first one on
the buffer and generate the output. Then I can load the second waveform
on the buffer and generate the second output. In order to minimize the
delay between the two output sequences, I would like instead to write
the buffer once. I tried to set the buffer size to 1000, and the number
of samples per second to 500, but it doesn't work. There is a way to
set independently the buffer dimension and the number of samples which
have to be generated?
