02-25-2015 04:56 PM
Hello all,
if i have for example an array with 0's and 1's
and i want to multiply each by a sine wave
and after putting it on a chart
i want to retrieve the bits again
how can i do that..i think i have done the first part where i multiply each number by the sinewave
but i don't have any idea how to retrieve them
Thanks all,
02-25-2015 05:52 PM - edited 02-25-2015 05:53 PM
Before attaching a sample VI, please populate reasonable default data into all controls and make the values the default. (currently, the array is empty and the numeric is zero).
Eldokch wrote:and after putting it on a chart
Thanks all,
Where do you want to retrieve the bits from? Form the chart data? The chart only has limited history!
I don't think you even did the first part yet.
I think once you specify in more detail what you actually want to do, the solution would be easy. 😄 At the moment, things are not clear at all.
