07-29-2005 03:17 PM
07-29-2005 07:49 PM
07-29-2005 08:37 PM
How about also posting an example of the plot showing the "star-like" features.
Mike..
07-30-2005 05:28 PM
Could it be that some of your 7 channels worth of y-value data is used as an x-value data when you feed it into an XY-graph? That could explain such 'star-shaped' features. Try to use a waveform graph instead of XY graoh then...
@tvratto wrote:I am using the daqpad 6016 to aquire 7 channels of analog voltage data from a device.I am getting large symmetric "star-like" features on my data graphs that appear to be related to my sample rate and are not being produced by my device. I suspect that these are due to some kind of buffering problem but I am not getting any errors from my vi. I'm using the Daqmx Timing (sample clock).vi and the Daqmx Read. vi with both of the samples per channel connected to a single number (500). I am sampling at 25kHz and averaging over 500 samples at a time giving me an effective rate of 50kHz. Any ideas?Tim
08-02-2005 12:02 PM
08-02-2005 12:07 PM
