05-21-2016 06:50 PM
I have led strip i want to control the intensity of its light ,iam using arduino with labview i want to make in labview every a specific time the intensity of light is increased by 10% automatically when my vi program is started and stops when intensity is 100%
i have already made it manually by switch using shift registers ,but i want to make it automatically every specific time
05-21-2016 06:55 PM
What do you mean by manually with shift registers? Hard to really understand that without the code to look at.
Whatever you're doing to increase it "manually," you can do automatically. Just add a wait(ms) and that'll handle the timing you need.
05-22-2016 05:22 AM - edited 05-22-2016 05:23 AM
here in my code each click on plus switch or minus switch i got the intensity increased or decreased by 10% .....i want to make that increase automatically by 10% every specific time without click switch when vi runs
05-22-2016 05:51 AM
i solved it ...i connected True Boolean instead of switch and it works very fine
thanks for your interest
