authenticating email sent from Touch Panel
I am trying to send a email from my Touch Panel application (TPC-2106 running Windows CE 5.0) to a list of recipients.  The 8.6 Touch Panel Module has a "smtp send email" function, however it does not provide the ability to authenticate the email message, and therefore really won't work with just about every email server.  I have come across some example code on the forum that shows how to authenticate an email message using a combination of .NET constructor nodes, property nodes, and invoke nodes.  I have successfully employed this code on another application that runs on a PC, but I can't use this on the Touch Panel application because the Touch panel module does not have the .NET constructor nodes.
Does anyone have any suggestions or work arounds?
Thank you.
(2,202 Views)
Did you try a search? This was recently convered at the end of this thread.
(2,194 Views)
