12-28-2015 05:20 AM
Hi everybody,
I'm a beginner in modelling with Labview (before I had done it in Matlab under syst ident tool box). Where should I start in Labview? I was trying study example Estimate Polynomial Models.vi. But it seems like I dont undertsnd. I hope someone can help me.
Thanks!!!
Solved! Go to Solution.
12-28-2015 07:31 AM - edited 12-28-2015 07:32 AM
Sounds like you need to learn some LabVIEW. There are numerous Tutorials (you'll need to spend a little time, but I'm sure, from your MatLab experience, you know that there will be a learning curve). Do as many of the exercises as you can -- you need to get used to programming "graphically". Try to study "good programs" to see what makes them tick. Don't be afraid to look at the Examples that ship with LabVIEW, including the Templates that can be found in the Getting Started with LabVIEW initial Splash Screen (they may be a little more complicated than you need, but they do represent NI's attempt to embody Good Practices).
One list of tutorials can be found in the upper right corner of the LabVIEW Forum's main page. Another, from the "Unofficial Forum Rules" is shown just below this line:
Looking For Free Training
Many times new users of NI hardware or software just don't know where to start. They will ask a question but without knowing the terms, or the intended purpose, they will not be able to form a proper question. Here are some free training tools primarily focused on LabVIEW and NI hardware to help get started.
-MyRIO Project Essentials Guide (lots of good simple circuits with links to youtube demonstrations)
Learn NI Training Resource Videos
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
The best way to learn, is to follow the tutorials, then ask lots of questions.
12-28-2015 08:43 AM
He/she has been "learning" LabVIEW since 2010. That's a long time.
01-01-2016 01:37 AM
Sorry..very sorry. Some misunderstanding here.
Yes, I used to use the labview before but not system identification tool box. And now I want to generate ARX model. Seems like I can produce the model but now I have new problem. Anyway MANY THANKS for your suggestions.
my questions are:
1. how to identify the best coefficients?(in matlab they produce the best fit and FPE value for this purpose)
2. Do I have to use "SI Estimate Orders of system model.vi" instead of "SI Estimate ARX Model.vi " ?
many thanks!!
01-01-2016 07:23 AM
I've done some modelling (typically fitting transfer functions and using models to suggest the system producing the observed system response), but was not familiar with ARX Modelling. However, a little Web searching led me to several LabVIEW references (probably more are in LabVIEW Help), including this one. I don't happen to have the System Identification Toolbox installed on my machines -- presumably this is part of your installation (and if it isn't, you need to obtain it!). How's your math?
