array transfer from a supervi to subvi, which runs independently of supervi.
I have been stuck on this issue for the past few weeks. I am using LabView 2014, and I have been asked to integrate a VI I worked on with another VI worked on by a colleague. For ease, let's call my colleague's VI as A, and mine as B
Basically, my colleague's VI is so large, with an i7 quad core, 8gb ram laptop to lag everytime I make any modification. To mitigate this, I made his VI to run my VI on start. It's not really a "subvi", it doesn't take any input or output. Important part is that they run in parallel.
Now, one import part is that I need to transfer an array of 10 numbers from A to B. B is quite large itself, and it has many inputs and outputs. It also has to work independently of A, because A has a delay of 0.5 seconds per cycle of its main while loop, and B has to make over 100,000 while loop cycles under an hour. In short, B MUST run in parallel with A, and I need to take 10 inputs(or an array of 10 numbers) from A whenever I hit a button from B.
I have read many discussions and used google search engine regarding this, I haven't found a definite way to make one vi to take input from the other vio without creating a new vi.
Any help would be appreciated. Thank you.
-SJL
(2,865 Views)
Queues, notifiers, global variable, functional global variables, user events... pick your passion!
(2,847 Views)
could you provide an example please? Global variable sounds most attractive to me.
-SJL
(2,838 Views)
Well it depends how critical the timing is. If you want it "at the press of a button" then it sounds like the timing might be critical. Otherwise all you could do in the VI that needs the data is see the most recent data written to the global variable.
(2,828 Views)
Or pass a control refernce to the array to B and use a property node to read the value.
Ben
(2,815 Views)
Since it sounds like you only care about the latest data when the button is pressed, I would say the global variable is the way to go here.  Use the File->New... menu item to open up a dialog.  In there is the option to create a global variable VI.  I'm sure you can figure it all out from there.
GCentral
(2,793 Views)
