08-10-2010 02:13 AM
Hi
I want to compare an array with a threshold value and then plot the values of the array which are above the threshold.
Thanks in Advance
Best Regards
RASHID
08-10-2010 03:39 AM
08-10-2010 07:48 AM
I would set the values that are below the threshold to NaN (Not a Number), this will prevent the plot from showing those data-points.
Ton
