09-16-2007 04:23 AM
09-17-2007 06:12 PM
Hi Kodeeswar:
I have a couple suggestions first try to create your analog input application with no digital or analog output task just "analog input" and then build the executable and try it again; second if it is possible for you please try updating to the new drivers of (NI DAQmx), and third reinstalling the last version of the “labview run time engine”. Also the 9172 is the chassis so which module are you using to handle the Analog Input application? To synchronize multiple modules or chassis if this is your case these links might be able to help you so please take a look at: NI CompactDAQ Module Synchronization, Synchronized Continuous Analog Input Across. I hope I was able to help you.
