Yes.
A computer needs the LV run-time engine to run executables built with LV, and the last tab of the app builder allows you to create an installer, which will install the LV run-time engine, along with your program, on any computer. This will increase your build time and your installation time considerably, so once you do this, you only need to replace the executable itself when you want to update the program.
You can also get the LV RTE and install it seperately.
___________________
Try to take over the world!
