appending digital and analog signals to a file
hello
i am taking a digital signal and an analog signal and want to append them to the one file. at the moment i am appending them to two seperate spreadsheet files but i would like to be able to append them to the same file. the digital signal is inside a stacked sequence structure that is inside a case structure that is inside a that is inside a while loop and the analog signal is inside a seperate while loop. how can i write the two values to the one file when they are in seperate while loops. i have tried to bring the data outside of the two loop but i am unable to do this
(2,243 Views)
Your description of your structure is very confusing.  And the fact you said you are using a stacked sequence structure means you have already set yourself up for some problems.
I can't visualize your code.  So please attach your VI so we can see what you are doing.
(2,236 Views)
Hi 4268,
Thank you for using the NI forums.. I agree with Ravens Fan. It would be useful to see how your code is architected via the VI please. This will allow us to help in the best method.
What type of data file are you using aswell?
Ash
Hi 4268,
Ash
Ashish Naik
Automotive Business Development Manager
National Instruments UK
(2,207 Views)
i am using a write to spreadsheet file
(2,201 Views)
Hi 4268,
Is it possible for you to attach your code to see how it is architected. This would allow us to help you in the best possible method.
If you cannot attach your code, can you please make a quick vi to show the architecture.
Hi 4268,
Ashish Naik
(2,177 Views)
