any fast way to move objects in front panel?
Hi there,
  I don't know if this is asked before. It is not a technical question but I wonder any way to move any object/control on the front panel quickly. I try to google and search in the forum but didn't see any way to do so. Sometimes, while developing complex program, too many controls used, after a control deleted and added back, it will appear in somewhere far away from the main region. I use mouse to move it back but it is so slow.
Also, in the diagram, for a big program, moving or lining from one end to other is so slow, any way to drag one line quickly from one end to other? Thanks.
(3,959 Views)
Accepted by topic author PKIM
@PKIM wrote:
Hi there,
With try and error, I just found that pressing SHIFT while moving the objects will speed it up.
(3,949 Views)
Also, make sure the naviation window is not shown when moving controls.  LabVIEW taking the time to recalculate the appearance of the whole front panel or block diagram to display in the navigation window slows down the operation as well.
(3,912 Views)
