08-18-2014 11:25 AM
The company I am working for is having thoughts about eventually migrating all software to LV 2014 and I'd like to know if the Unicode properties and methods will survive an upgrade to LV 2014 from 2009.
As always... THANKS, EVERYONE!!!
08-18-2014 01:09 PM - edited 08-18-2014 01:11 PM
I haven't played with Unicode much in LabVIEW at all, but one thing about 2014 would make me weary! LabVIEW 64 bit for MacOS X uses now Unicode strings as default string format. So they certainly made substantial changes to parts of the LabVIEW code dealing with Strings. I would expect that a large part of the changes are hidden behind a pre processor define that only gets active when compiling for Mac OS X 64 bit (Cocoa) but since Unicode support in other platforms was never released there is a good chance that some of the improvements made it into the standard LabVIEW code that gets enabled with the undocumented INI key.
So chances are pretty big that there will be changes on other LabVIEW platforms when using Unicode features that only are available using the INI key setting, since NI is unlikely to have done many unit tests on the unreleased Unicode feature.
08-18-2014 01:53 PM - edited 08-18-2014 01:54 PM
That's... a little scary...
Guess we'll throw the code in the water and see if it sinks or swims... CDs due to arrive any moment.
