I am delveloping a data aquisition VI, I am using the DAQmx and it works fine. I am using the amplitude and measurement express vi to obtain data such as peak to peak etc... I can aquire up to eight channels using the DAQmx, just by selecting the physical channels, but the amplitude and level measurement vi only seems to give me the value of one of the signals (the first one aquired), even though two are being displayed on the graph or even three. How can I display all the peak to peak values for all waveform simultaneously. I am aware that the measurement express is a dynamic data type and conversting the output into an array would work, but I keep on getting errors. Any advice. Attached is the VI and a snapshot of the VI. I also tried splitting the signal with no luck.
Thank you
