03-14-2012 05:07 AM
Hi all,
I am looking for a version of advaced signal processing to work with labview 2011 64 bits and I can't find anything. Is it possible to work with labview 2011 64 bits with this toolkit?
Thanks in advance.
Juan Luis
03-14-2012 09:49 AM - edited 03-14-2012 09:49 AM
Juan Luis
At the moment, most toolkits and modules of LabVIEW are only presented in 32-bit versions. However, you can easily install those toolkits and module on a 64-bit OSs and they work as you would expect. You just need to install the 32-bit version of LabVIEW before installing the software.
See more information in here:
http://digital.ni.com/public.nsf/allkb/71E9408E6DEAD76C8625760B006B6F98
Hope this helps.
03-15-2012 04:40 AM
Thanks for the answer, but ,How can I use the 8 GB of RAM that my laptop has? with the 32 bits version of labview it is not possible. Isn't it?
Many thanks
03-15-2012 10:17 AM
Yeah. if you would need 64-bit OS for that. Can you describe your application? Or which function are you interested using in ASPT ? Maybe we could find workaround for you.
06-11-2012 12:33 PM
LabVIEW 2011 (64-bit) Advanced Signal Processing Toolkit has been released on April 17, 2011.
06-11-2012 01:25 PM
Mikhail:
I think you intended to state April 17, 2012 as the release date.
-AK2DM
06-11-2012 01:51 PM
Yes, you are correct. Thanks for pointing that out.
06-12-2012 03:00 AM
Thank you very much
