08-25-2009 03:02 PM
HI can anyine suggest how to create a signal from the data in the 2d array... i was able to display the data using a chart...but i want to create a signal...for tat i need time values too..but the vi which i have doesnt give me the time values....if i use absolute type of time, im getting the date and time(HH:MM:SS) in the 2d array in a very akward manner..... how to get time in seconds rite from the start of scan?
08-25-2009 03:33 PM - edited 08-25-2009 03:34 PM
Here is a snippit of the end of my "scan" sub vi.
The ouput is both string, string array, numeric, and numeric array.
That way I can use une sub vi for all my scans, if it is one channel or a series of channels
You should be able to take the numeric array output and sned it to a chart or graph
08-25-2009 09:03 PM
Since it is a picture it is not very clear how it works..Can you please explain on the logic...and where is the time(in secs) being extracted?
08-25-2009 09:26 PM
1.I managed to figure out that scan from string vi has been used to convert string to numbers...however later some array function has been used i dont what vi is it and why it has been used and as mentioned before where is the time stamp extracted and how?
2.Moreover what is the advantage of advanced scan vi I was told earlier that the scanning sound is absent if advanced scan is used but it does not seem to have stopped?
3.Thirdly the advanced scan functions are available only for data logging or is it avilable for agilent 34907A multifunction modules also?I know there are drivers for this analog module too but are there different vis like EZ and advanced?
clarifications in this regard will be appreciated...
08-25-2009 09:37 PM
http://forums.ni.com/ni/board/message?board.id=170&message.id=404360&query.id=1230096#M404360
THe above link has one way of extracting time ..But I really dont understand how it works...
08-25-2009 09:45 PM
08-26-2009 01:39 AM
Hi find attached a simple vi to plot data in a strip chart using the extracted numerics in an array.
First depending on what we read and howny data we read we need to index the array by having suitable i and j values to extract one value from the array and then wire it to a bundle...and then to astrip chart.
note that in the left bottom of the pgm there is a portion to intialize and create x axis time..I also dont understand the details exactly but the whole pgm works i collected them from different examples.
note when you copy the intialization part into your pgm it will be unlinkled..you will have to right click the property node and select link to and select the name/label of the strip chart and it works.....
If there any better ways to extract the time and data as discussed in the previous post please do let meknow..
08-26-2009 08:37 AM
08-26-2009 08:49 AM
08-26-2009 08:59 AM
siva0182 wrote:Since it is a picture it is not very clear how it works..Can you please explain on the logic...and where is the time(in secs) being extracted?
Time is seconds is not extracted, only the readings.
I simply use Labview's built in VI's to create my timestamps.
