NI Home
Cart Cart | Help
You are here:
Reply
Member
siva0182
Re: advanced scan vi agilent used for continuous measurement
Please find attahed the vi where the string is converted to number.I hop ethis works I am not too sure..try it out and use the indexed array of nos and wire it to a chart.
Also Even though i have the agilent driver I am not able to open the vis in the file you have uplaoded. Can you please give me the links from where you downloaded the driver and which exact version are you using?Are you  using serial communication?
Member
pri2686
hi thanks....i will try this tomorrow when i go back to my office..... im using labview 8.6....i requested for an evaluation software form NI... dey have provided the device drivers cd too,.....when i open the 'find instrument drivers' it automatically downloads the necessary drivers for the specified instrument...i will send u the link tomorrow....
 thnks once again...i will get back to u once i tried the vi which u have provided!
Member
pri2686
yeah..im using serial port for communication...rs-232 cable....baud rate 57600, flow control xon/xoff...
Member
siva0182
Hi
Thanks for the info. I mangaed to get the drivers and my pgm too is working fine.
The main problem with the drivers is WE SHOULD NOT RESET !!!!!.
i dont know why...
anyways I am also stuck up now in extracting the data into numerics and time stamp.
I tried the pgm which i sent you but it works only for the integral part of the data the decimal is lost...So i think some thing needs to be modified to extract the whole data...i did search in the forum reg string to number..in ni forum ..but there are reference only to different codes to convert string to codes..I am stil exploring for the best option..
Any ideas to extract the whole data into number is welcome.
Also How did you extract the time stamp?
Member
siva0182
Any means using std vis  to convert to number?
also any insight onto why "choosing reset" causes error?
Active Participant
billko
I'm assuming "choose reset" sends an reset command to the equipment, causing it to be unavailable while it is resetting (I believe it's called a "Pre-set" in HP/Agilent-speak).  That would cause an error when you tried to read from it right after.  Ugh, this is all so difficult with RS-232.  At least GPIB is smart enough to wait for the instrument to come ready.  You also wouldn't have to insert delays in your code because the VI would just sit and wait for something to show up in the buffer.  Of course, both of those scenarios depend on your VISA timeout being longer than it takes for your instrument to send something to the buffer!
Bill
Bill
CLAD (Still lowly minion - just not quite so lowly.)
Member
pri2686
Hi
i dont know why...
Hi...
i set up the time in the instrument also i gave an option in the scan field (boolean) for absolute and realtive time.... hmmm.... i seriously do not know how to do all this stuff..... i juz started using LABVIEW 4 days before...but i have been assigned this work...so i need to finish and learn as well :smileyhappy:
i will try the vi which u sent me..
thnks
Member
pri2686
Hi siva....
i was to able to get the decimal part too.......instead of using decimal string to number .....use frat/exp to number...simple..we will get the value of current with decimal places...i am attaching the vi here.....
so..now my question is... are these values of current enough to create a waveform chart?? the readings array is a 2d array but has only the values of the current...so using this can i create a chart??
thnks
Member
pri2686
Knight of NI
Dennis_Knutson
Yes, you can wire a numeric to a chart. You are going to have to use the index array function to get the value out of the array. I don't know which element to extract since you did not post a VI with any values. You would have to run it until you get some values, stop the VI, go to the edit menu, select Make Current Values Default, save the VI, and post that. Otherwise, just experiment with the index array function. It's pretty basic.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
