I was programming some function in dll with LabView.
With the C code provided, I can handle most of them. For example, when the dll function is "ReadOutData(unsigned int uiChannel, double uiData)", then I know I have to set two parameters in the dll property as unsigned integer and double, and link two numbers (integer and double) to the boxes.
Now come to a special case, the dll function looks like: "ReadDataAddress(unsigned int &uiChannel)".
How do I handle such operator "&" in LabView?
Thanks in advance!
