01-31-2013 07:05 AM
I am trying to save as much screen space as possible...Is there a way to add custom buttons to the Labview toolbar? Adding splitter bars for toolbars takes up too much space for my application...
Solved! Go to Solution.
01-31-2013 08:12 AM - edited 01-31-2013 08:13 AM
In a VI go to Edit >> Run-Time Menu to change the menu seen to the user when the VI is running.
To handle when a selection is made use the Event structure. There are are several shipped examples in the Example Finder.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
01-31-2013 08:22 AM
Thanks for the reply but that deals with Run TIme Menus for text drop downs from the existing menu items and customizable text items. What I was looking for was something similar to in Excel when you define a macro and attach it to fire from a custom button. From what I see, it is not possible to add an actual button to the main menu toolbar that is not previously on the menu. Am I correct?
01-31-2013 08:25 AM
Sorry my reply didn't help I wasn't sure if that's what you were looking for or not.
I know of no way to do what you are saying easily. That being said it sounds like a neat UI design and would be nice to have.
01-31-2013 08:32 AM
Hi id,
What is your "main menu toolbar" actually?
Why shouldn't you be able to place another boolean button (maybe customized with some decal)?
01-31-2013 08:45 AM
What I called the main menu toolbar is the labview one at the main window that contains the run arrow, stop, and pause buttons normally. My main menu has about 4 additional buttons to add to this toolbar
01-31-2013 08:48 AM - edited 01-31-2013 08:52 AM
Hi id,
and you need to have those 4 buttons in the development environment? I don't know a way to add more buttons to that toolbar...
But you can add your tools (aka VIs) to the tools menu!
When you're talking about an executable (or running VI): your user should never see the toolbar menu! It's just for the IDE...
01-31-2013 08:51 AM
That "menu" bar should not be visible to a end user running your program.
That is only for development use.
You need to make your own menu bar if you need one.
01-31-2013 09:02 AM
and the only way to do that is to add a horiz splitter with my buttons above it or to add it to the drop down run time menun listings as text items correct?
01-31-2013 09:03 AM
