adding custom buttons to toolbar
I am trying to save as much screen space as possible...Is there a way to add custom buttons to the Labview toolbar?  Adding splitter bars for toolbars takes up too much space for my application...
Message 1 of 15
(4,126 Views)
In a VI go to Edit >> Run-Time Menu to change the menu seen to the user when the VI is running.
To handle when a selection is made use the Event structure.  There are are several shipped examples in the Example Finder.
Message 2 of 15
(4,115 Views)
Thanks for the reply but that deals with Run TIme Menus for text drop downs from the existing menu items and customizable text items.  What I was looking for was something similar to in Excel when you define a macro and attach it to fire from a custom button.  From what I see, it is not possible to add an actual button to the main menu toolbar that is not previously on the menu.  Am I correct?
Message 3 of 15
(4,110 Views)
Sorry my reply didn't help I wasn't sure if that's what you were looking for or not.
I know of no way to do what you are saying easily.  That being said it sounds like a neat UI design and would be nice to have.
Message 4 of 15
(4,107 Views)
Hi id,
What is your "main menu toolbar" actually?
Why shouldn't you be able to place another boolean button (maybe customized with some decal)?
Message 5 of 15
(4,104 Views)
What I called the main menu toolbar is the labview one at the main window that contains the run arrow, stop, and pause buttons normally.   My main menu has about 4 additional buttons to add to this toolbar
Message 6 of 15
(4,099 Views)
Hi id,
and you need to have those 4 buttons in the development environment? I don't know a way to add more buttons to that toolbar...
But you can add your tools (aka VIs) to the tools menu!
When you're talking about an executable (or running VI): your user should never see the toolbar menu! It's just for the IDE...
Message 7 of 15
(4,095 Views)
That "menu" bar should not be visible to a end user running your program.
That is only for development use.
You need to make your own menu bar if you need one.
Message 8 of 15
(4,091 Views)
and the only way to do that is to add a horiz splitter with my buttons above it or to add it to the drop down run time menun listings as text items correct?
Message 9 of 15
(4,086 Views)
Hi id,
you don't need a splitter to place some buttons...
Message 10 of 15
(4,082 Views)
