04-03-2012 06:31 AM
hi
i have -labview 2011, -LVFPGA, -RealTime, -NIRIO 4.0 , -cRIO mdk 2.0 and -cRIO module support 4.0.1..
i m working on building a new module.. firstly, i want to control chassis slots.. So, i run, software part of that
application ==> http://zone.ni.com/devzone/cda/tut/p/id/7868
and it works.. i see the signals on my oscilloscope..
The problem is i couldn't find a way to add generic module to my own FPGA project...
i also investigate the sample application giving this link ==> http://zone.ni.com/devzone/cda/tut/p/id/4539
and it shows adding cRIO-generic module to embedded project.
here is my way
* i m creating an empty project and adding cRIO-9004 by >> right click(Project) >> New >> Target and Devices >> Real-time compactRIO >> cRIO-9004
* and then, right click, FPGA Target (cRIO-9103) >> New >> C Series Modules >> New Target or Device >> C series Module
but i couldn't see "generic" module ...
What i m missing?
Solved! Go to Solution.
04-03-2012 12:38 PM
I had the same problem. Would show up under 2009 but not 2011. See this:
I added the line 'cRIO_FavoriteBrand=generic' to the ini file. It now shows up under 2011.
