activex automation not implemented in NI_report generation toolkit
Hi all,
Getting a report generation toolkit error for the first time.
Image is attached.
Anyone seen this error or know why it might occur?
-Matt
(2,895 Views)
Hi Matt,
nice error message.
And how does your VI look like?
(2,892 Views)
Hi GerdW,
i often forget to check google before i post, but NI has a solution to it HERE.  I had a case strucure and was using set excel worksheet inside of it in every case except the default, then i used the easy excel text.  You have to have the set excel worksheet in front of the easy excel text if you use the set worksheet i guess.  My application shouldnt ever be going through the default case which makes me wonder, but its working fine now.  So i think ill let it be. Smiley Indifferent
-Matt
(2,886 Views)
