acquiring data only once while generating other data continously
I am using Labview 2009 on windows 7 PC and I am using NI USB6009 for my application.
In my vi I want to generate ramp voltage continously which I can in my current vi. But while doing this I will be connecting relay contact to other digital input. I want to store the generated ramp voltage at the instance when the relay closes its contact which I will know as it is connected to the digital input. The contact is going to remain closed for a while but the instance at which is closes is of value to me. I tried various things using case structures or even parallel while loops. but unfortunately I am not so much acquainted with event structures so I couldn't achieve what I wanted. Please help me out.
Rohan
(2,370 Views)
Accepted by topic author r_te
Hi Rohan,
pseudo-code:
IF RisingEdge(digital input) THEN
  store current AO value in shift register
ENDIF
 You need the PtByPt_BooleanCrossing function, a shift register and a select node…
(2,366 Views)
how do I get the rising edge is what I don't know
(2,354 Views)
Hi Rohan,
as I said before: you need to use PtByPt_BooleanCrossing
(2,350 Views)
thanks a lot
(2,343 Views)
