access fpga register on host
Is it possible to use Registers in the LabVIEW FPGA just like front panel controls / indicators?
I had difficultiy finding that option from FPGA Palette.
When I tried drag and dropping this feature in my host this is what I got?
Do I have to create a custom interface using front panel terminals to pass values to my register?
Maciej
(3,000 Views)
Also I noticed that it is possible to put the reference to the Register to my front panel of the FPGA vi... but I don't know how to access it from the host,
I don't see it on the list of controls and indicatiors with the usage of property rear/write node.
(2,993 Views)
There is currently no support to access Registers (or Handshakes) from the host, they are target-scoped. If you need access to them on the host you will need to use some other mechanism like controls/indicators, DMA, etc. to get the values to/from the host.
(2,984 Views)
Thanks a lot for the prompt reply.
What is the reason of being able to pull out the I/O reference than to a front panel control?
Is this in order to be able to select which register I'm working on for testing?
Maciej
(2,977 Views)
Accepted by topic author Mac671
Testing is one use case. It is also useful when you want to create reusable subVIs so you can pass different references to each call of the VI.
(2,975 Views)
