about change the size of the panel and centerlize the window
Hi there,
  I have a simple subvi, it has a string indicator embeded into the panel. I have the string fit to the pane. I am going to change the size of the panel to width 240 and height 24 then centerlize the panel. I found some code in the forum. If I don't put the string there, the code works perfect. But after putting the string, it will run into error.
And I call the subvi FP.vi in a main vi (main.vi).  The error is
Error 1 occurred at Property Node (arg 1) in FP.vi->main
Possible reasons(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
Property Name: Front Panel Window:Panel Bounds
Any suggestion why this error?
Message 1 of 10
(3,613 Views)
Accepted by topic author PKIM
I don't see a reference to the FP subVI in your image.  You need to have a VI reference going into the FP.PanelBounds Property Node.
Message 2 of 10
(3,605 Views)
Left unwired the property node uses "This VI" as a default value.
That works OK
Do you have a minimum size set in the vi properties?
"Should be" isn't "Is" -Jay
Message 3 of 10
(3,599 Views)
Yes, I thought he was trying to call a subVI reference, though.
Anyway, I played around with the same VI's and I get the same error message if I try to use the same coordinates, but when I increased the bottom coordinate to a value of 26 then I don't get the error.
Message 4 of 10
(3,592 Views)
Here is a snippet that worked for me.
Message 5 of 10
(3,590 Views)
Yes there is a minimum height for string indicators you violated that
Message 6 of 10
(3,584 Views)
I put everything in the subvi and I call the subvi in other code. I wonder if that subvi refer to itself automatically
Message 7 of 10
(3,567 Views)
I just test that without the "This VI" it doesn't work. Thanks for your pointing out.
Message 8 of 10
(3,558 Views)
Thanks for pointing that out. I just want to know how to figure out 26 is the minimum coordinate I should use other tha something else. Instead of hardcoding that, anywhere I can refer to so to get the minimum? Thanks.
Message 9 of 10
(3,556 Views)
Min size is a property of many controls.  it changes.  for instance, with a silver style string control its 37 pixels high with the default font size. ( it Makes sense, that it shows 1 line of text clearly)
By scaling to pane- the string min size is forced into the min pane size of the 1 pane panel (FP) so setting the height lower than the control could show 1 line of text clearly yielded an error.
Or, in other words, the error explaination could have been clearer when it was first implemented.
Message 10 of 10
(3,551 Views)
