a tool that removes all VIs not in memory, in a folder and its subfolders
Anybody have such a tool they'd share?
(2,161 Views)
Would you settle for the invers function i.e. copies all VI's in memory to a new location ?
In LV 7.1 and prior that would be save with options single prompt preserve hierachy
In LV 8.X and forward, create a source distribution with similar settings.
Otherwise, please ignore this post.
Ben
(2,158 Views)
Theres a property of application called All VIs in memory. This will give you an array of VI names. Now get all the files in a directory using List Folder.vi, search the array of VIs in memory for each file, if it's not found, delete it.
(2,151 Views)
That'll work, thanks.
(2,149 Views)
Also, I was just playing around with this and remembered that there is a VI in the advanced file functions palette called Recursive File List.vi. I think it's new in 8.2, so if you have it you can use it to get filenames for all subfolders as well.
Message Edited by Marc A on 02-27-2007 02:00 PM
(2,145 Views)
