That sounds strange, Anne. Did you try using the Highlight Execution button or the other techniques I recommended above? My guess is that you are not reading the responses as fast as the device is sending them, so they stack up in the receive buffer.
You can flush the receive buffer, Anne, but you might cause problems if it's in the middle of receiving a packet when you flush it. It's safer to use a while loop to just keep reading responses with the non-blocking read VI until it returns false, then use the Request VI to send a request and receive a response. That's equivalent to flushing the receive buffer, but won't leave you with half a response in the buffer.
