02-26-2012 04:20 PM
Hello Dear All,
in our project we have to control yokogawa wt3000 using LabView Software. We have used driver from the yokogawa site for the device and it works well via GPIB connection, but not via LAN. We called the support from Yokogawa and National Instruments and found out, that we have to use the tmctl.dll library (see 2 pdf-files in attachment).
I've tried (not sure, about that. It is correctly ?):
Tools -> Import -> DLL
there I've choosed the tmctl.dll and tmctl.h files
and LabView has created a lvlib with several VI's (Tmc ****.vi and x TMC ****.vi)
I've got a couple of questions.
How have I to change the source-code where I use "normal" (yokogawa driver for GBIP) VI's
(do I have to do it ?).
Can I use the driver from yokogawa or have I to write a new one?
What else have I to do?
If you need more information, let me know.
Thank you very much !
Best regards:
Alexander
The files we've got:
tmctl.lib
tmctl.h
tmval.bas
tmctl.bas
TmctlAPINet.dll
ykusb.dll
YKMUSB.dll
USBTMCAPI.dll
tmctl.dll
and TMCTL library user's manual with describtion for using with Microsoft Visual C++
Solved! Go to Solution.
02-26-2012 09:52 PM - edited 02-26-2012 09:57 PM
Perhaps I am not understanding your questions, but it appears that there are two ways to access the functions to control the instrument via Ethernet.
One way is to use Call Library Function Node (Connectivity -> Libraries and Executables) and call the tmctl.cll
The other way is to use the .NET elements (Connectivity -> .NET) and call TmctlAPINet.dll
The readMe text files included with the driver files explains the various functions and parameter lists.
EDIT: It does look like you can create wrapper VIs of some of the functions to control the instrument. If you don't need the functions for which no wrapper VI can be created, then that appears to be the way to go.
02-27-2012 01:53 AM
I think you also asked this question at customer support in Amersfoort The Netherlands ?
I am working on it to find the cause of your problem. I will let you know.
02-27-2012 06:15 AM
It wasn't me 🙂
Thank you for helping me and sorry for my unclear questions.
I'll try it again:
In our source-code we have used several VI's from labview driver for wt3000 (ykwt3000.llb) (for example initialise, set voltage, set current, set/read items and others) and it works correctly over GPIB (or serial) but we need that it works over Ethernet.
We found out, that we have to use the tmctl.dll library but we dont know how to. The describtion in the manual for tmctl-library isn't easy/understandable for me (I'm not familar with Virtual Basic or C++).
The question is how to use the VI's created from tmctl.dll library? Do I have to use only these VI's and have to replace all VI's from driver for GPIB (the driver uses ascii commands).
For example:
to read data over GPIB you can use a Read-VI that send the ascii command ":NUMERIC:LIST:VALUE? 1" and get the values after that, but over Ethernet it doesn't work. What have I to change on the Read-VI or which tmctl-VI have I to use to read the data? And so for all VI's.
I hope my problem is clearer now.
Cheers:
Alex
02-27-2012 06:20 AM
Hi Alex,
OK, I have a WT3K on my desk working with GPIB and Ethernet.
In MAX you have to add a LAN instrument through a manual entry of a raw socket. Fill in the IP address of the WT3K and use port 10001. Fill in an alias and use that alias as the VISA resource name in the WT3K VI.
If you don't understand above I will make screenshots to make it clearer.
Success, Kees
02-27-2012 07:42 AM
Sounds good, I'll try it out (unfortunately I can do it first next week, have no access to yokogawa now).
I can remember, I've used this port but not via MAX (in VISA for initialisation I've used the string: "**:ip_from_wt:10001:**" and sent "IDN?", but the answer string was strange). I hope it is not the same to initialse in VISA with ***:ip:port:***-string and to create a alias in MAX.
Thank you Kees.
I'll let you know, if it works.
Alex
03-01-2012 12:28 PM
I need help to link the wt3000 to labview by ethernet. I need only read numeric data but I can not establish a connection. can you help me?
03-01-2012 01:49 PM
Hi fcfcfc,
Is the WT3000 present in MAX?
03-01-2012 05:48 PM
No. I can not add it. I have tried add it but it was not recognized.
Appear a message to add it offline...
03-02-2012 04:40 AM
Hi all,
Maybe the attached document will help to add the WT3000 in MAX.
If not just let me know.
Kees
