Xor operation for Hex Values
Dear sir,
I have to apply Xor operation for 03, 01, 57 & C9 Hex values.
In programmer Calculater I have applied like: "03 Xor 01 Xor 57 Xor C9 = 9C". Finally the output is 9C.
How to implement the same operation LabVIEW?
S Nagaraju
(4,758 Views)
Accepted by topic author Sonti_11532
Try this
(4,746 Views)
Other options:
The FOR loop is more "scalable"…
(4,740 Views)
Thanks for the replay.
Actually the Hex Values are available in string format and seperate into bytes.
Please check the attached snippet and let me know still if any simplification possible.
S Nagaraju
(4,718 Views)
Hi Sonti,
you don't need to split the string:
(4,711 Views)
Thanks for the replay,
Depending on my application my string length may vary. In that case i can use a for loop with exclusive or function after type cast right.
Rhanks & Regards,
S Nagaraju.
(4,705 Views)
You can both the ways, glad that both arrived at same method
(4,673 Views)
