08-29-2005 02:42 AM
08-30-2005 08:11 PM
Sasi,
I am not quite sure what you mean by repeatability plot. Can you explain that more?
If I understand correctly, you want to keep the different data and results from different files seperate. In that case, you might want to keep track of the number of element in each file and then in your final array that contains all the resulant data, you can split that up into sub arrays based on the number of elements in each file.
Please let me know if I have misunderstood your question. Thanks.
Jack J.
09-02-2005 02:43 AM
Hi Jack,
Thanks for ur reply,
1) sorry what i explained is not clear, repeatability plot, i want to find the repeatability of the diffrent datas so if i plot in the same XY- graph i can compare the plot visually that the all the plots are more or less similar.
2) i want to to select diffrent data from diffrent file but the first column of all the datas will be same & number of datas i am selecting is same for all the files,
eg. in first column if i have No. like 1,2,3,4,5,6.......20 & second files first column data is also same, now i am intrested to select datas 1,2,3,4,5 only from both (all) the files i am selecting.
Please let me know if u have any doubts, Thanks.
Sasi
IIAP
09-06-2005 09:12 AM
