XY Plots features with 2 Y Scales
I have LabVIEW v6.1, Windows 2000. I have an XY plot with 2 Y Scales, which works fine. I only have 2 trends on the plot. I can use the tool pallets in runtime to change the appearance of the graph to suit my requirements at the time, but I can't make the graph always revert to default scale values when I enter the VI again. How do I force the chart scales to always start at default values every time the VI is opened? Is there a user function during runtime on the pallet which makes the graph scales go back to defaults that I have configured? Or are there properties I can access using a property node which can force the scales to min/max values that I want? There are Y scale properties that do this, but how do I select the Y scale that I want to work on at the time?
Regards
Andy Back
(2,187 Views)
To select a specific scale, first use the property Active Y Scale. Then you can use Y Scale Range Minimum and Maximum to set it to any defaults that you want. You could also try Y Scale>Scale Fit to force an autoscale once.
(2,172 Views)
Thanks Dennis, worked fine.
(2,160 Views)
