04-27-2015 02:22 PM - edited 04-27-2015 02:23 PM
I use an XY Graph to draw some limits. These limits are given by the plot 0 and plot 2 which is why I have them set to "Fill to positive and negative Infinity" respectively.
Problem is, I now have another plot (plot 3) to display which doesnt fall within the specified "limits" drawn by plot 0 and 2. The result? Plot 3 is being covered almost entirely by the other plots with the "fill to.." option.
TL;DR: Is there a way to make the plot 3 display over its entire length without being covered by the fill to x infinity plots?
Current result:
Desired result:
Solved! Go to Solution.
04-27-2015 02:23 PM - edited 04-27-2015 02:24 PM
Change to order of the plots and put the limits at the end.
04-27-2015 02:29 PM
I thought I had tried that once before... guess I didn't!!
Thanks altenbach!!!
