Dear LabVIEWers,
I was wondering if anyone has ever confronted the following issue and possibly if there is a solution:
I am using XNET Read (CAN Frame Input Queued) function to read some CAN frames. I am perfectly able to set the "Number to read" property and it reacts well. As soon as I specify a parameter for Timeout property, it does not read any frames anymore and directly pops up a Timeout error after x(specified) seconds.
While I was trying the same thing using XNET Read (CAN Frame Input Stream), I did not face such a problem.
Is there some one who experienced this before and know a solution ?
Ps: My Hardware is NI-PXI 8512 HS/FD
Ali
