08-16-2006 04:29 PM
08-16-2006 05:56 PM
Hi Bill,
This won't always happen. The Value Change event case in the owning VI will only execute if you set the Data Change element of the Action Cluster to True. Otherwise, it doesn't happen. So if you set that value to true in the Data Change event case in your Facade VI, which executes everytime a new value is written to the XControl via local variable, then yes, it will fire the Value Change event case. Otherwise, it won't (it didn't on my computer, in any case 🙂 ).
08-17-2006 08:20 AM
Here's an example that shows the difference between causing a Value Change vs. not causing a Value Change event when writing a value to an XControl's local variable.
08-17-2006 01:40 PM
Jarrod,
Thanks for the help, I see what is happening now.
Bill F
