Write to spreadsheet does not work
I am comparing a string I enter in a text box, to a string in a .csv. If the string is found, the data is written to a file, but if the string is not found, some other data should be written to another file, but nothing happens. I used the copy of the code that worked with the true case, but I still can't fix this problem.
Can someone please help me?
Thanks!
(2,695 Views)
What you described should be possible. Please post your code along with some typical strings and a small sample .csv file.
Lynn
(2,686 Views)
Accepted by topic author Nando88
I figured out what was the problem. I was using 2 write to spreadsheet vi's, so the data was written in a file that was not the correct one.
(2,649 Views)
Any error code you receiving ?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,647 Views)
