10-05-2014 04:46 PM
I am comparing a string I enter in a text box, to a string in a .csv. If the string is found, the data is written to a file, but if the string is not found, some other data should be written to another file, but nothing happens. I used the copy of the code that worked with the true case, but I still can't fix this problem.
Can someone please help me?
Thanks!
10-05-2014 04:53 PM
What you described should be possible. Please post your code along with some typical strings and a small sample .csv file.
Lynn
10-05-2014 10:18 PM
I figured out what was the problem. I was using 2 write to spreadsheet vi's, so the data was written in a file that was not the correct one.
10-05-2014 10:18 PM
Any error code you receiving ?
