JoeWork wrote:
I was wondering with the way you presented your code in your picture that you post why you didn't see an error window pop up on the issue with the file name? Unless that was a bug for the LV version you are using?
If the Automatic Error Handling is turned off (which I prefer), then you will not get an error message for the unwired error outs. Proper error handling can easily take care of that problem.
