Write string columns to Spreadsheet
I have problem.
I have a device which generates 3 data, eg. voltage, current, frequency.
When I run the program, all values are put under him, but I would like to were in the 3 columns.
For example:
Voltage      Current   Frequency
2                 1               5
4                  4              5
5                  3              6
The second problem is related when i run program continously. Values are not added to the column but overwritten.
What do I need to change the program to act as my premise?
Regards
(5,222 Views)
Accepted by topic author piotrek1349
Don't use Save Spreadsheet String, but use the Write Delimited Spreadsheet function from the File I/O Palette.  Incidentally, I hope you realize that "Spreadsheet" in "LabVIEW-Speak" means "A text file where data are arranged in rows (with New Lines) and columns (with some to-be-specified separator character).  It does not mean "An Excel .xls or .xlsx file".
(5,216 Views)
Yer doin' it wrong...
First write your column headers to the file ONCE at the beginning.
Then write your numeric values in ROWS as a single demention array
=== Engineer Ambiguously ===
(5,205 Views)
Ok,
First problem solved:) Thanks!
But,
How to add next values to the spreadsheet when i run program continously?
At this moment the values are overwritten.
(5,192 Views)
Use a loop
(5,185 Views)
how are you writing your row of strings in the first array?
I do not understand where you get that string format of many columns from?
(3,338 Views)
Hi lodhi,
When you write "columns" you should think of "array"!
Use a string array constant…
(3,330 Views)
