Write analogue channel to CAN bus
I have a cDAQ with a number of analogue and digital I/O modules installed. What I would like to do is take some of the analogue inputs and transmit them onto a CAN bus using the NI 9862 module. I know the basics of how to read the analogue data but I'm not sure how to get this onto the CAN bus, does anyone have a sugested starting point?
Richard
(2,150 Views)
Hi Richard,
as you use the 9862 on a cDAQ you should have XNET driver installed. This driver comes with a lot of example VIs. Start by studying them!
You need to define a CAN message containing your "analog" signal. Then you send that message using XNET write message function…
(2,145 Views)
