01-25-2014 06:58 PM
I'm currently reading voltage data serially via USB (COM port) and I'm trying to use the "Write to Measurement File" block to log some of the data that gets passed through.
For both cases, when using the Write To Measurement block:
- I experience lag in the rate at which data gets plotted to the Waveform chart and,
- The written file ends up with data that has duplicate timestamps with different values.
I've searched for similar issues in the forums but I couldn't seem to find anything relating to this issue. Is this a known issue? How would one go about ensuring that a set time delta restriction is in place?
Any insight would be appreciated.
The VI configuration and .lvm buffer are attached below.
I am sampling at a rate of 1 kHz (PIC18F2550) and sending the samples out via UART (19,200 baud rate) protocol to be plotted on a waveform chart.
01-25-2014 07:31 PM
01-25-2014 09:12 PM
In terms of odd wiring, are you referring to the blocks inside the case structures that encompass the boolean switch followed by the "Serial Config + Verify" block? I wasn't sure if this was the best approach but I essentially want the COM port config to be accessed globally throughout the various tab control modes.
I should clarify, by timestamp, I was actually referring to the first column in the attached bufferdata.txt file which I believe is in milliseconds. I was wondering why there is multiple data points for the same time value?
01-25-2014 09:17 PM
01-25-2014 10:54 PM
Alright, after looking more into Tab Control's properties, I found the "Value" property which signals whenever a tab has changed wheras the Tab Control's enum does not and would require constant polling (which according to some other posts is greatly inefficient).
I deleted the original "Write To Measurement File" block and added another one and now I'm getting data in a totally different form. So as far as I understand, the only way to get time data (elapsed would be preferred vs time stamp seconds) would be to transform the input data into a waveform type?
Attached is the current output of the new "Write To Measurement File" block
01-25-2014 11:38 PM
01-25-2014 11:43 PM
01-26-2014 10:19 AM
How else can you access the active tab control page without hooking up to the tab control?
01-26-2014 11:08 AM
Well, how often do you want to read the value of the control? In your example it will be read once. (That's all the number of times you read the value from the terminal, ONCE when the vi starts) The value input into the while loop's tunnel cannot change even when the value of the control changes since the terminal cannot be read more than once.
01-27-2014 09:44 PM
I too have this question, regarding the data logging.
If my data is being sent serially 1 sample every millisecond to the serial read, is it crazy to expect that after starting the program a logging function would produce the roughly the same as the following:
Time (s) Value
0.000 250
0.001 275
0.002 300
0.000 250
0.003 275
0.004 300
0.005 250
0.006 275
0.007 300
I understand that there will be slight offsets in time as the modules take time to run but each sample coming in should have its own time value that is roughly 1ms apart from the previous and next values right?
My data is logging in a similar fashion as the OP's result, with some samples coming in with the same time value, which doesn't make sense if they are transmitted 1ms apart. Instead of the desired table I receive something like the following:
Time (s) Value
0.000 250
0.000 275
0.000 300
0.001 250
0.001 275
0.002 300
0.002 250
0.002 275
0.003 300
